-   Dodge Dakota Forum (https://www.truckforums.com/forum/dodge-dakota-forum-9/)
-   -   02 dodge dakota shift / starting problem (https://www.truckforums.com/forum/dodge-dakota-forum-9/02-dodge-dakota-shift-starting-problem-14798/)
jynov Oct 4, 2010 09:12 AM
I have 02 Dakota quad cab, auto transmission, 4.7 V8. Sporadically, when turning the key, the shift indicator will light up around the P but as soon as I try to start it, it goes out and the truck won't start / do anything. It happens off and on and when I shift through the gears, it'll light up around everything except park and neutral. Then after 5 or 10 minutes of trying every type of variation with the key, gearshift, stepping on brake etc., it'll magically stay on and start. Any ideas?
RovinAround Oct 6, 2010 12:41 PM
Possibly a short across the ASD relay??
atul1 Feb 24, 2011 05:04 AM
Kindly check distributor cap and rotor to check out there are no carbon deposits or water inside, if that is fine then check your coil wire whether it is functioning properly, check all your spark plug wires and check out that they are dry.
jynov Mar 25, 2011 09:00 AM
atul1 - It doesn't have a distributor cap - why would coil wire or spark plugs have any affect on gear shift indicator - problem has nothing to do with that
