Dodge Dakota Forum Discuss the Dodge Dakota here.
1991 Dakota starting issue
Old 05-06-2017, 09:14 AM
spsmith's Avatar
Default 1991 Dakota starting issue
Vehicle: 1991 Dakota S 4x4 with 5.2 liter V8 - Auto trans - 198K miles
This issue started with the engine going into a high idle condition at random intervals. Generally, this could be stopped by a hard application of the throttle. This went on for about two weeks. Yesterday it turned over normally, but refused to start. It is not displaying a check engine light.
I'm sure there are several possible causes like the Idle Air Control Valve or perhaps the Throttle Position Sensor. This is my first Dodge vehicle so I'm at a loss. What is the most likely cause? I have very limited funds so any and all help will be greatly appreciated.
Thank you in advance.
Old 05-12-2017, 10:53 AM
Tried cleaning out your MAF sensor? I had a weird idling and running issue with my truck and found a tiny piece of fuzz in there last week
Old 06-25-2017, 08:47 AM
spsmith's Avatar
Both the MAF sensor and IAC have now been replaced. When it is cold the engine will start and run. If I run it up to normal operating temperature and shut it down it won't start. I guess the next move is the Air Charge/Manifold Temperature Sensor.
Old 08-26-2017, 05:06 AM
spsmith's Avatar
In the end it was a bad fuel pump. That has been replaced along with the external fuel filter. I still have a rough idle, but I suspect a tuneup will clear that up.
The only other oddity is a "surging" when driving at 35 mph +/- 5 mph. This can be an rpm change of as much as 200 rpm. This is a puzzle yet to be solved.
Old 09-04-2017, 10:01 AM
spsmith's Avatar
So the "surging" issue has been solved as well. In keeping with the MOPAR reputation for being "picky" the transmission was 1/2 quart low on fluid. The issue went away with an added 1/2 quart. The trans has since been serviced.
baddmaxx25
01-10-2011 09:40 AM
seantheleprichaun
05-04-2010 06:52 PM
turbohvn
04-03-2009 03:32 PM
jss5891
02-13-2009 08:04 PM
87V6Dakota
10-04-2007 09:17 AM
Quick Reply: 1991 Dakota starting issue
