-   Dodge Dakota Forum (https://www.truckforums.com/forum/dodge-dakota-forum-9/)
-   -   95 dodge dakota (https://www.truckforums.com/forum/dodge-dakota-forum-9/95-dodge-dakota-20457/)
roberthd Sep 25, 2014 06:22 PM
95 dodge dakota
I have a 95 dodge dakota when its idling and have hood open i can hear air building up then it stops then check engine light comes on does any one know what that is? thanks
mrdarcy Mar 31, 2015 07:53 PM
Could be an idle air control valve, that's the device that controls fuel-injected vehicles like your 95 dodge dakota to regulate the idle speed of your engine. It's controlled by the engine's computer, it's a bit complicated so can consult this for more info, hope it helps. In any case, i'd have a trusted mechanic do the work to be sure. Good luck.
GMCSierraFan Apr 1, 2015 11:20 AM
Before anything, I would go down to autozone and have them pull the codes for you. This will help point you in the right direction.
As I have found with my Honda, A lot of times a gunked up throttle body can cause erratic running and throw false codes, so I would start by cleaning everything up
