1999 ram
<UL>
<LI>the speedometer and cruise control is also notworking and stopped functioning at the same time as the ABS/Brake light came on. </LI>[/list] </P> Any help Thanks </P> David</P><edited><editID>jds313</editID><editDate>38180.5164930556</editDate></edited> |
RE: 1999 ram
There is a sensor in the rear end (I know, it sounds strange but this happened to me.). not sure what it's called. Change or get it changed. If you should change the fluids in the rear end be sure to add special additive for limited slip diff. otherwise you'll get a strange reaction when making a tight turn and eventually burn up rr
RE: 1999 ram
try checking out dodgeforum.com... lots of good ram info there!
| All times are GMT -5. The time now is 10:35 AM. |
