20 inch rims
Old Jul 15, 2009 | 03:51 AM
tae's Avatar
tae
Default 20 inch rims
Will 2006 Dodge Ram 20 inch rims fit on a 1997 Dodge Ram 1500 2 wheel drive?
_________________
"It don't mean **** right now... Daddy's won here 10 times." - Dale Earnhardt Jr.\\ Camshaft Bolt Lock Plate on the loose.
Old Jul 16, 2009 | 08:55 AM
Dodge Craig's Avatar
Not sure if you will run into brake disc / drum and fender clearance problems and the tires you use can also cause clearance problems.
Did you try those online tire / rim companies like tirerack.com ....
Maybe Dodge dealer could help,
but you may end up with 2010 RAM!
Old May 22, 2010 | 12:47 PM
Nando Vazquez's Avatar
3rd generation rims will fit on 2nd generation rams, IF they are the polished aluminum. The chrome covered rims will not clear the front wheels without some adjustments to the rims or spacers.
Old Jun 29, 2010 | 01:21 AM
andii's Avatar
Banned
I think it is not possible to add 20" rims on 1997 Dodge ram. I will tell you with in three days after disusing with my mechanic.
Old Jul 15, 2010 | 11:59 PM
mikesheldon's Avatar
Banned
They will not fit, I don't know if the bolt pattern is the same or not but the studs are bigger on the new rams then yours.
Old Nov 9, 2010 | 11:07 AM
jamesjohn012's Avatar
I think they will not fit but not sure.. once consult the dealer.
Old Dec 16, 2010 | 02:58 PM
ModzMan56's Avatar
Originally Posted by Dodge Craig
Not sure if you will run into brake disc / drum and fender clearance problems and the tires you use hid headlight kits can also cause clearance problems.
It shouldn't be a problem. There are certain models of rims that will not fit though so you have to watch out for that.
Old Mar 1, 2011 | 12:58 PM
kingrob84's Avatar
reliable cars
Dusty's-Sierra
Feb 18, 2013 10:05 PM
hathaway
Jan 26, 2012 11:30 AM
xaviergzz
Silverado/Sierra FAQs
Oct 25, 2010 07:46 PM
Radoz71
Apr 4, 2010 09:14 PM
jason10560
Automotive Parts Wanted
Aug 22, 2007 01:26 PM
