20 inch rims
Will 2006 Dodge Ram 20 inch rims fit on a 1997 Dodge Ram 1500 2 wheel drive?
_________________ "It don't mean **** right now... Daddy's won here 10 times." - Dale Earnhardt Jr.\\ Camshaft Bolt Lock Plate on the loose. |
Not sure if you will run into brake disc / drum and fender clearance problems and the tires you use can also cause clearance problems.
Did you try those online tire / rim companies like tirerack.com .... Maybe Dodge dealer could help, but you may end up with 2010 RAM! |
3rd generation rims will fit on 2nd generation rams, IF they are the polished aluminum. The chrome covered rims will not clear the front wheels without some adjustments to the rims or spacers.
I think it is not possible to add 20" rims on 1997 Dodge ram. I will tell you with in three days after disusing with my mechanic.
They will not fit, I don't know if the bolt pattern is the same or not but the studs are bigger on the new rams then yours.
I think they will not fit but not sure.. once consult the dealer.
Originally Posted by Dodge Craig
(Post 47323)
Not sure if you will run into brake disc / drum and fender clearance problems and the tires you use hid headlight kits can also cause clearance problems.
reliable cars |
| All times are GMT -5. The time now is 05:24 AM. |
