95 ram
I have a 95 ram 1500 3.9l 2wd with 210 000kms so i guess around 130 000 ish miles on it... the body is beginning to get pretty rusted and the paint is starting to peel off. i plan on keeping this truck till it dies so i was planning on doing a body job and a "rustoleum" paint job on it to make it a little more appealing. my question is, do you guys think worth putting the time into this truck? or will it die soon?
cont.
also.. found out the dipstick is broke, but i do know its due for an oilchange.. since i cant check the oil level until i get a new dipstick, does anybody know the amount of oil I would need to do an oil change on this truck? thanks
Gasoline Engine Oil should be at least API SH or SH/CD with the correct viscosity for the temperature chart below.
http://dodgeram.info/tech/BRSpecs/fluids/G-oil.gif Engine Oil Capacity V6 4.5 qts. V8 5.0 qts. V10 7.0 qts. |
I would prefer you to change the oil as oil plays an important role, it would be help your truck to run smooth.
