Check engine light
I have an '05 Ram on which the engine light has come on. A quick diagnostic check by a mechanic says it is on due to an "evap leak". He claims this is not a concern and that it is difficult to find and it poses no serious threats to me. Comments, suggestions?????
it will not cause any drivability issues or damage any components. The evap system is used to prevent vapours from the fuel tank escaping into the atmosphere.
Usually, small leak detection require the use of an evap smoke machine and a scan tool that can seal the evap system. Post the code that has set and maybe someone here can help. |
2 reasons to fix it.......Wont pass emissions test.......Check engine light on drives me nuts........
Have you tried replacing the gas cap yet?
Originally Posted by poncho62
(Post 82681)
2 reasons to fix it.......Wont pass emissions test..............
