drag link
Can someone tell me what a drag link is? I have a 2005 Dodge 2500 making a noise when i hit the slightest bumps. The dealer told me the drag links needs to be replaced. I looked for parts called a drag link and haven't had any luck Any ideas?
RE: drag link
slang for a "center link"..what the idler arm and such bolts too...it'd have to be loose as hell to make your noise though
RE: drag link
The drag link is the first rod that is moved when you turn the steering wheel.
RE: drag link
Term drag linkrefers to the two sleeved bolts that connect the center link arm to the steering knuckles. When I took my '06 in for servicing in August they informed me there was a recall to replace the center link and drag links and all bushings. Any of these bolts or bushings worn will really make a noise at the slightest movement.
