dropin or sray on
Old Mar 26, 2008 | 12:03 AM
megaram12's Avatar
Default dropin or sray on
i am looking into buying a bedliner, should i go with a dropin factory or a sprayed on? I have heard that the spay ons are better but they are pricey? Are they worth the extra money are they that much better then the dropins
Old Mar 26, 2008 | 08:54 PM
racethisz71's Avatar
Default RE: dropin or sray on
i have a drop in im pulling it out and im doing hurcaliner is like $50 i did on my firends truck and its really easy if you go for spray on dont do linex i wrecked linex in my old truck and they wouldnt warrenty because it was a work truck
Old Mar 27, 2008 | 06:11 AM
Argon's Avatar
i hate those drop-ins....an ice chest slides around like a waxed hockey puck!
plus,they rub all the paint off underneath.
just get a GOOD mat,or spray in
Old Mar 27, 2008 | 10:27 AM
jcbst12's Avatar
Spray in definately
Old Mar 31, 2008 | 10:22 AM
Purcell's Avatar
Depends on what you do with the truck, if you haul loose material (gravel, dirt, etc.) the drop in liner is slick and easier to unload, if you haul coolers and boxes, then the rollon or sprayin is the way to go since they do not let things slide around. I have a drop in and use a pole with hook to drag boxes to the rear so it works for me. New truck has a drop in mat, I will put a roll on coat below this and on the side to protect the paint.
Old Aug 28, 2008 | 05:09 PM
JHS8503's Avatar
If you put a drop in liner in your bed, you might as well not put anything in! When you are through with the truck, the bed will look as bad as if you didn't put anything in it at all! Not to mention, nothing stays in place. I have had more trucks that I have fingers and toes, and I do everything from throwng a cooler in the back, to farm/ranch chores with mine. I won't use anything but a spray in liner. It's well worth the extra money! Remember, you get what you pay for!
Old Sep 1, 2008 | 12:14 AM
karl's Avatar
If you frequently transport heavy cargos in your truck, you may consider the drop-in because spray ons are tend to be thinner than drop pins.
