Ram 3500 Dually
I am looking at buying a used Turbo Diesel Dually. I don't really plan to tow anything except maybe a trailer when I move, but I want a turbo diesel dually because of the power and looks. So for a to be used as a normal truck what year 2001-2004 would be best to buy and would one with 100k-150k last for a while? I don't want to spend more than 19K on it and it seems that for those years that is the mileage I am looking for.
Also what are some known problems. |
RE: Ram 3500 Dually
Two problems I found:
#53 blocks stamped with 53 are bad and the water jacket lining breaks below the exhaust manifold VP44 Injector pump dies because the lift pump doesn't output enough to it. So it looks like when I do go buy one I'll end up buying a new lift pump (aftermartket) and putting it on the frame and installing a fuel pressure gauge. |
RE: Ram 3500 Dually
have you found one I have one listed on here, or you can email me at urbrat77@aol.com or call 618-513-2459 the only problem mine has 182000 miles but I am only asking 10K
