Stereo Wiring Help!
I got a 2006 Dodge Ram 1500, 7 Speakers ~ Without Navigation System. I am getting a new stereo for it. But what I am wondering is, How do I wire it? What do I need? Like all I need is a dashkit, stereo, wire harness, and antenna adapter. & for wiring, is it color to color. Is there wire's on the factory harness that wont be on the new wire harness. Also I need a wiring diagram for the stereo for my type of truck. I have posted this on many other forums and I never get a complete and clear answer!
You are correct on most of it, and the rest you may have a difficult time understanding until you actually have it apart.
You need: -dash kit -Wiring harness -Antenna adapter -stereo -Either wire nuts or solder (i prefer solder) The wiring harness will come with a wiring diagram. You then take the harness for your vehicle and the harness for the stereo and solder the proper connections together and wrap in tape. There should be about 8 of them I believe. The antenna adapter will be a direct plug in. The dash kit is a different story as I've found that those universal ones almost always require modifications that are a pain in the butt, but sometimes they work fine. To answer your questions- yes, there has always been a few wires on the stereo harness that don't go to anything on the truck. I would recommend taking out the old stereo and creating your "new" harness first- then plugging it in and verifying that everything works (all speakers, radio etc) Then unhook everything and tackle the dash kit. You may have to reference a few youtube videos for this though. Hope this helps |
| All times are GMT -5. The time now is 09:41 AM. |
