Vacumm leaks?
Have 1999 2500 4wd with 5.9 gas engine. Started having vacumn leaks. I assume thats what the problem is, cause when you put a load on the engine, the ac vents close. Also gas milage getting worse. Anyone having suggestons give me a holler. Thanks.
RE: Vacumm leaks?
its ur check valve on your brake booster, change it, takes 2mins!
RE: Vacumm leaks?
all its doin is losin the vacuum to hold the doors open, it makes the air come through the defrost vents.
RE: Vacumm leaks?
try checking out dodgeforum.com... lots of good ram info there!
