ABS/Speed Sensor Brake light on
<UL>
<LI><FONT face="Arial, Helvetica, sans-serif" size=2>1999 dodge ram 5.2 liter </FONT></LI> <LI><FONT face=Arial size=2>lost my speedometer not working</FONT></LI> <LI><FONT face=Arial size=2>ABS light on</FONT></LI> <LI><FONT face=Arial size=2>no Cruise</FONT></LI> <LI><FONT face=Arial size=2>Brake light on</FONT></LI> <LI><FONT face=Arial size=2>So what is the problem</FONT></LI> <LI><FONT face=Arial size=2>74.358 miles</FONT></LI> <LI><FONT face=Arial size=2>David</FONT></LI> <LI><IMG src=smileys/smiley6.gif border="0"></LI>[/list] |
RE: ABS/Speed Sensor Brake light on
first thing check all fuses. after that you might be looking at a bad wheel sensor, that would cause the lights,
Same thing happened on my Dak.Not sure if they are the same though,but when it happened to the Dak my rear abs speed sensor had went bad.It is located on the rear end housing.
i worked for dodge for a while, and we replaced alot of these. also, did the ABS light come on at the same time that the speedo quit working? the two possibly could be unrelated.
