Dodge 2500 Front End Problems
<FONT face="Arial, Helvetica, sans-serif" size=5>I have a 1996 Dodge Ram 2500 4x4 diesel.</FONT></P> <FONT face=Arial size=5>I developed a pulling to the right and my steering wheel is off center. Apparently this is a Big Problem for Dodge p/u's. The part is question is the infamous " Trac arm ".</FONT></P> <FONT face=Arial size=5>Any one else had/has this problem ?<IMG src=smileys/smiley19.gif border="0"></FONT></P> |
RE: Dodge 2500 Front End Problems
its a constant problem with the rams, i cant tell you how many front end alignments ive done on rams. doing them is a pain in the ass. as long as everything in the front end is tight and not worn have the truck aligned. although try rotating the tires first, it is quite common for improperly rotated tires to cause pulling, swap the tires in an x-pattern and test drive it, see what happens
