-   Dodge/ Ram General Tech (https://www.truckforums.com/forum/dodge-ram-general-tech-36/)
-   -   Transmission help please. (https://www.truckforums.com/forum/dodge-ram-general-tech-36/transmission-help-please-6842/)
jagxtype Apr 6, 2008 09:42 PM
Truck Info:
96 Dodge ram 2wd 1500
5.2L V8 engine
133,000 miles-trans already rebuilt once by aamco and is out of warranty and not sure of miles when rebuilt
So, the truck will not move and when shifted out of park (R,N,D,2,1 it does it in all these) it sounds like a hydrostatic lawnmower or weak power steering pump. It does this and it varies directly with engine speed. It seems like it really wants to move (and does a little once in a while), but at the same time the engine free revs. Front pump problem? Torque converter problem? Electric solenoid problem?
Any help would be appreciated. Thanks in advance
Argon Apr 7, 2008 06:15 AM
RE: Transmission help please.
sounds like burnt clutch plates...does the fluid stink?
jagxtype Apr 7, 2008 08:02 PM
doesn't it always...haha...smells like normal! The fluid is new anyhow.
Argon Apr 8, 2008 04:34 AM
somethings failing to get a nut then,..the front pump you mention is a good possibility...the line pressure needs to be checked
