-   Dodge/ Ram General Tech (https://www.truckforums.com/forum/dodge-ram-general-tech-36/)
-   -   white smoke coming from exhaust (https://www.truckforums.com/forum/dodge-ram-general-tech-36/white-smoke-coming-exhaust-13007/)
almt1357 Mar 8, 2010 11:17 AM
hello, I would really appreciate it if someone can help with my question. I have a 2003 dodge ram 1500 8cylinder 5.7. I have to have my catalyc converter replaced, could this be the reason for the white smoke coming from exhaust? What is the best converter to purchase for my year/model?
Thank you
Daarrve Mar 8, 2010 02:46 PM
Thank you
The last time I had white "smoke" coming from my exhaust I had to get a headgasket job done on the engine. I really hope this is not the case here.
almt1357 Mar 13, 2010 07:02 PM
I hope that is not the case that sounds costly, but thanks for your input.
Worf Mar 14, 2010 06:57 AM
I agree white smoke normally means blown head gasket
Rob Cook Apr 12, 2010 02:49 AM
headgasket jog is first option, & secondly may be change with latest from company dealers.
mikesheldon Jul 21, 2010 03:06 AM
When the vehicle is idling walk around the back by the exhaust if you can not smell oil burning or do not notice a sweet smell do not worry about it. If you do notice a sweet smell it is because you have antifreeze leaking into the exhaust system either from a bad head gasket or a crack in the head or block. Hope this answer helps
austin72 Oct 29, 2010 12:41 AM
Is the white smoke was come before you replace the converter?
Same problem i have in my 2006 dodge, the white smoke come at the time of morning when I start my truck. After 10 min it stops coming white smoke because of engine warms up.
AbleSmith Dec 27, 2010 12:12 AM
Head gasket is blown dude, no doubt about it. common issue with them. if you want to keep the truck, put the stud kit on the head to eliminate that, then install the EGR bypass kit...
atul1 Feb 22, 2011 03:53 AM
Kindly check rings in the engine whether worn, if it is then needs to replaced, or may be there is problem with head gasket, check the same.
honestblades Feb 22, 2011 08:36 AM
It could be either a head gasket or an intake gasket. Regardless of which one is the culprit,it sounds like you have water in your engine.
