-   Dodge/ Ram General Tech (https://www.truckforums.com/forum/dodge-ram-general-tech-36/)
-   -   won’t idle (https://www.truckforums.com/forum/dodge-ram-general-tech-36/wnt-idle-63/)
tedprice Jun 19, 2004 09:14 PM
won’t idle
my 99 ram 1500 5.2L has a defective speed sensor, the speedometer does not work, also when i stop or let up on the gas pedle it will go dead. it always recranks but will not run at idle. my autoxray 5000 scanner will only detect a bad speed sensor in the trouble code area.
does anyone have any suggestions ?
thanks.
tp1484@highstream.net
cheevers Jun 5, 2005 01:37 AM
RE: won’t idle
well you have to use a computer to find out which speed sensor is bad. and the stalling issue cant be caused by a speer sensor, your looking at 2 completly different issues.
Dodge_man Dec 27, 2005 10:40 PM
RE: won’t idle
Same as the last guy.. you have to use the db2 or db3 to figure it out
