Dodge/ Ram Heavy Duty Discuss the 2500 and 3500 Heavy Duty Dodge/Ram Pickups as well as the Cummins diesel.
broken tension arm
Old Feb 2, 2013 | 09:17 AM
dctilp98's Avatar
Default broken tension arm
My wife was driving her '04 Dodge 3500 5.9 Cummins on the freeway at 80 mph, the tension arm broke at some point she lost power steering and then brakes. She's wondering, with very good reason, why there were no warning lights or alarms? We had a '97 Ford F350 and 2 squirrels took out our belt and every light and alarm went off - luckily it was parked. Why no warnings on our Dodge?
Old Feb 2, 2013 | 09:41 PM
RustyFordLover's Avatar
It seems like the battery light would have come on, or at least the check engine light.
Old Feb 4, 2013 | 08:17 AM
Diesel Dan's Avatar
This does not make sense.
On the Cummins Diesel the power steering pump is gear driven. It sits below the injection pump and behind the vacuum pump. The serpentine belt drives the water pump, A/C compressor, alternator and cooling fan. The vacuum pump and power steering are not belt driven.
Old Feb 4, 2013 | 08:58 PM
Also..Wasn't 2002 the last year they used the 5.9?
Old Feb 4, 2013 | 10:12 PM
Diesel Dan's Avatar
No, 2006 was the last for the 5.9L.
The 6.7L is basically the same design however.
Few more electronics and variable vane turbo.
Old Feb 5, 2013 | 01:43 PM
I thought the 6.7 had more valves. I don't know much about diesel engines though.
Old Feb 5, 2013 | 10:11 PM
Diesel Dan's Avatar
The 6.7L is a 4 valve per cylinder design with cam in block.
In Ram trucks the 5.9L had a 2 valve head(12 valve) from 1989-1998. From 1998.5-2007 it had a 4V head(24 valve).
hga
9
Jul 8, 2015 03:13 PM
korygrandy
May 6, 2010 08:17 PM
dabatman99
Nov 27, 2009 11:23 AM
bpa1216
Sep 17, 2009 08:39 PM
Dodger
Jul 2, 2004 03:36 PM
