Dodge/ Ram How-To's and Tutorials Have a project you're working on? Take pictures and write up a procedure...We'll post it here!
How to: Easy way to check for a bad alternator
Old Apr 10, 2010 | 04:01 PM
Worf's Avatar
Default How to: Easy way to check for a bad alternator
If you've been wondering how to test the Alternator on your truck... this is the test to do.
It'll help you to diagnose a BAD Alternator in a pinch. It's a fast test and more importantly an effective test to find out if the alternator is in fact bad.
This test doesn't require any tools, such as a multimeter or anything else. And whether you're driving a Ford, a Dodge, a Chevy, or whatever, this test will work.
Also, you can avoid the most common mistake made when testing an alternator of disconnecting the negative terminal of the Battery while the engine is running. Not to mention that this is a really, really bad way of checking for a bad alternator.
Here are the common symptoms of a BAD Alternator:
The vehicle does not start.
You know it's not the Starter Motor because if you Jump-Start the vehicle it Starts and Runs but after a few minutes or seconds after you disconnected the Jumper Cables from your vehicle's Battery, the vehicle dies.
Or the vehicle may stay running for a while until you start turning on accessories (like headlights, a/c, wipers, etc.).
The Battery light comes on and stays on the whole time the vehicle is running.
At night, when you turn on the headlights, both headlights and dashlights are very dim.
Here is how to test without any tools
Start the vehicle. Either jump-start it or charge the Battery to get it started.
Open the door and leave it open so that the dome light can come on and stay on.
Disconnect the jumper-cables or whatever it was that you used to start the vehicle.
Go back to the inside of the vehicle and eyeball the dome light.
If the vehicle stayed running after disconnecting whatever it was that got it going, then notice the dome light's intensity.
Now turn on the headlights and notice the light's intensity once again.
The light should dim a little and then resume its brilliance to the way it was before the headlights were turned on. If this happens the alternator is doing good.
If the light dims and DOES NOT return to its previous intensity and CONTINUES to dim, the alternator is faulty.
With the vehicle running and with the headlights still on...
Turn on the blower motor on high and notice the light's intensity once again.
The light should dim a little and then resume its brilliance to the way it was before the headlights and the blower motor were turned on. If this happens then the alternator is doing good.
If the light dims and DOES NOT return to its previous intensity and CONTINUES to dim, the alternator is faulty and not charging the Battery or supplying the vehicle's electrical needs.
If the alternator is BAD, as you turn on load after load (headlights, blower motor, wipers, turn signals, etc.) then eventually the dome light and the headlights will get very, very dim till the vehicle stalls.
If the alternator is not BAD, then the dome light and the headlights will stay on and brightly lit (after a slight dim as the load normalizes) no matter what you turn on.
It doesn't matter how discharged the Battery is. After the vehicle is started, either by a jump-start or by charging the Battery, this test applies.
Old Sep 1, 2012 | 01:44 AM
nelsee's Avatar
Banned
Such symptons which is been provided with an good guideliness and the information which is been quite good and very intellectual too.
Old Sep 10, 2012 | 03:40 AM
jeslin_G's Avatar
Thanks for sharing the useful information to check for a bad alternator. I was searching for the same information and i finally i got my answer through this post.
Old Nov 29, 2012 | 01:17 AM
roshanill's Avatar
Just take the battery into the service counter, usually the clerk will know exactly why you are there and take you down to the end of the counter where they have the battery load tester and it will only take a few minutes. If the battery is badly run down you may have to wait for a while (or come back in a couple hours) as the battery will need to be charged to be tested properly.
Old Nov 29, 2012 | 08:10 AM
RustyFordLover's Avatar
He didn't say anything about battery's, he was talking about alternators, completely different parts.
Worf
GM How-To's and Tutorials
Dec 5, 2012 03:34 AM
Worf
Dec 4, 2012 03:59 AM
Worf
Apr 12, 2010 02:44 AM
Worf
Ford How-To's and Tutorials
Apr 8, 2010 04:14 PM
Worf
Apr 8, 2010 04:02 PM
