2011 4x4 front leveling kit
my xl sits with the nose way down i want to level the truck out
does any one know of any good leveling kits in all price ranges thanks for the help |
The cheapest way is to put a leveling spacer on the strut assembly. It's about 1inch thick and bolts to the top of the strut (your coil over shock assembly). They usully sell for $100 or less for two. They do restrict your up travel and can over extend your down travel compared to stock and if you do a lot of off roading you may notice it. I have used them on my 04 Tacoma without any problem. The better way is to replace your front shocks with Bilstein 5100 shocks. They have a clip you can set for different heights up to 2.5 inches. The shocks run about $80 each maybe a little more. The 5100 does not restrict your up or down travel.
check out hell bent steel they make a good and cheep spacer. how much space between the tire and fender? check them front and back and the difference is what size you need!
| All times are GMT -5. The time now is 05:24 AM. |
