F150 issue (desperate)
First do you get any response from your starter when you turn the key? If you put your lights on and the radio do they dim way down when you try to start?? Just because your lights work does not mean that the starter will turn over the engine. That starter draws allot of AMPS.
Are your cables on the battery clean?
The battery is most suspect if the starter will not engage. Clean the cables, make sure the battery has water in it ( unless its a sealed battery) . Charge the battery over night, then check each cell with a hydrometer.
They should read in the 1250 range. Try it one more time. Then see if it will start with a jumper from another vehicle. Sometimes if your battery is shot it won't start with a jumper cable. ( BE sure you use all the precautions in your owners manual if you attempt to jumper your battery.
miltonluban
Aug 14, 2020 07:25 AM
dragonslayer
Feb 26, 2019 02:38 PM
JHinckley1983
Aug 13, 2009 06:19 PM
