Give your F150 an additional shine with new Morimoto Tail Lights!
Morimoto's wide product line has been recently expanded with the fresh XB-Series Black/Red and Black/Smoke LED Tail Lights. They feature unique one-of-a-kind design and cutting-edge lighting technologies this brand is famous for. The Morimoto company has once again outperformed itself and created a whole new line of innovative and bright XB-Series LED tail lights that will enhance the appearance of your 2015-2017 Ford F-150 and make it stand out on the road. XB-Series lights are manufactured from the finest quality materials with great attention to details. Each set of tail lights comes with multiple SSC LEDs to ensure sharp light contour and high brightness. The lights are a snap to install. They come with easy to follow step-by-step instructions, so the whole installation process can be performed as a fun DIY project. Morimoto® - XB™ Red LED Tail Lights https://www.carid.com/images/for-for...-tl-ford-1.jpg https://www.carid.com/images/for-for...-tl-ford-2.jpg Notes: Not compatible with non-US spec cars. Replaces Original (OE) Part #:FL3Z-13404-A, FL3Z-13405-A Specifications: - Bulb type: SSC LED - Functions: turn/brake (dual intensity), backup light - Housing material: injection molded ABS - Lens material: UV-resistant high impact polycarb - Connector: Ford multi-pin OEM - DOT, ECE, SAE, FMVSS compliance - IP67 waterproof - LED color: red (brake, turn signal) Morimoto® - XB™ Black/Smoke LED Tail Lights https://www.carid.com/images/for-for...-tl-ford-1.jpg https://www.carid.com/images/for-for...-tl-ford-2.jpg Fits: 2015-2017 F-150 with Factory Halogen Tail Lights Will not fit models with Factory LED Tail Lights or BLIS (Blind Spot Information System) Notes: Not compatible with non-US spec cars Specifications: - Bulb type: SSC LED - Functions: turn/brake (dual intensity), backup light - Housing material: injection molded ABS - Lens material: UV-resistant high impact polycarb - Connector: Ford multi-pin OEM - DOT, ECE, SAE, FMVSS compliance - IP67 waterproof - LED color: red (brake, turn signal) Features: - Will give your vehicle an additional gloss and shine - Boast a durable and lightweight construction - Made with easy and effortless installation in mind - Offered with all necessary hardware for easy wiring - Backed by a 5-year warranty https://www.carid.com/morimoto/ Get more information about the new line of Morimoto XB LED Tail Lights here. |
| All times are GMT -5. The time now is 06:59 AM. |
