-   Ford F-150 Forum (https://www.truckforums.com/forum/ford-f-150-forum-16/)
-   -   How many inches of lift to fit 37' tires (https://www.truckforums.com/forum/ford-f-150-forum-16/how-many-inches-lift-fit-37-tires-8890/)
pullmeout Jan 20, 2009 07:40 PM
Well I have this '83 F150 that I'm going to turn into a wheeling truck now as the title states I would like to know how much liftI need to clear a set of 37 or 38 inch tires in the front
any info will be greatly appreciated and for those that may inquire about rear clearance that is a none issue it has a flat bed
karl Jan 21, 2009 09:43 PM
RE: How many inches of lift to fit 37' tires
Getting a quality 6-inch lift, the 37-inch tires will fit in.
TRuckster Jan 26, 2009 10:19 PM
I've seen a Black 2004 F-150 model last weekend with an 8" lift and 38"tires on it... It really looks sweet... Love it!
rollingthunder Jan 29, 2009 08:15 PM
6" should be plenty for a pavement pounder....
However you said you want to go wheeling, so I assume you want room for flex.....
I'd go with 8"
Cheap way would be 6" suspension and 3" body....
I'm not a big fan of body lifts, but they have their purpose...
You also may want to upgrade to 3/4 ton axles, or atleast put 4.10s in your stock..... 38" inches is a lot of rubber to turn....
