Save 20% OFF on aFe Scorpion Grills at CARiD
https://images.carid.com/afe/promo/a...r-promo-18.jpg https://www.carid.com/afe-power/ A new grille can turn your truck into a real head-turner. A powerful LED light bar on your front-end can bring light to any off-road trails. Now you can get the best of both worlds with aFe Scorpion Series LED Grille! This rugged grille features a laser-cut and TIG-welded construction with a two-stage coating for maximum durability and resistance against dirt, debris, and corrosion. High-intensity CREE LED lighting is included with every grille. With a 6000K color temperature and combo beams, its perfect for use on the country roads. This kit installs behind the factory grille with no cutting, drilling, or modifications required. This fall, you have an opportunity to save 20% on aFe Scorpion Grills. The offer ends on November 30, 2020. Prices are already reduced. aFeŽ - Scorpion Series Tread Design LED Grille https://www.carid.com/afe-power/scor...ed-grille.html https://images.carid.com/afe/items/79-21008l-p.jpg https://images.carid.com/afe/items/79-21008l-wf.jpg https://images.carid.com/afe/items/79-21002l-p.jpg https://images.carid.com/afe/items/79-21002l-wf.jpg Features: - One-Piece Laser-Cut Design - Two-Stage Powder-Coated Finish - Built-In LED Lighting - Stainless-steel hardware is included to provide the best corrosion resistance possible for each application Includes: - 1-Pc main grille - Military-grade wiring harness - Stainless steel installation hardware |
| All times are GMT -5. The time now is 05:45 AM. |
