which should i get???
i jus got my 1st truck, its a '95 F-150 4x4 shortwheelbase, straight 6, manual trans, XL package, i am goin to lift it but cant decide wether to get the 2.5" or the 4". im gonna prolee run 35s and i know i can clear them w/ either lift but i seen the 4" lift on a truck and didnt like the way it was sittin. it wasnt level, it was leanin forward like it does stock. will the 2.5" lift do that too or will it level it out, and is there a 4" lift that will level the truck out??? thanks for all input.
RE: which should i get???
Hello on a true lift kit you are getting 4" all the way around I assume you are lifting the suspension and not the body? For and Chevy put blocks on the rear to ofset the loads according to there enginer's as in the past you would see a old truck going down the road dragging the bumper they wanted to get away from that. Back to your Question on a suspention you will be removing the old block and using there's so the truck will be level
