-   Ford F-150 Forum (https://www.truckforums.com/forum/ford-f-150-forum-16/)
-   -   white smoke (https://www.truckforums.com/forum/ford-f-150-forum-16/white-smoke-10589/)
jd1200 Jul 7, 2009 08:10 PM
white smoke
I have a 2008 f150 and till yesterday it was great I went to work and about 10 miles down the road from my house it started to pour out white smoke from the tail pipe not just pouring but billowing i had tocontinue to drive for 20 more miles because I was on the interstate now the motor is locked I have been told by several people that there was something put into the gas what else could have caused it?
bradsharp Jul 7, 2009 10:20 PM
does it smell like coolant? if so you could have a blown head gasget or cracked head/block. you should take it to a mechanic as soon as possible because if that is the case you could hydra-lock the engine. would be a bad thing to screw up a good engine over a cheap fix. also has the check engine light come on or anything in that matter?
jd1200 Jul 8, 2009 06:28 AM
smoke
no I had no engine lights no warning it went from great to poof overnight
bradsharp Jul 8, 2009 08:36 PM
if it is still under waranty i would just take it in to the repair shop to be safe. i can't really think of anything except water getting inside the cylinders. witch i you should have checked immediatley expecially if there is any knocking or loss of power. if the dealer or repair shop that covers your waranty is far away i would might even go as far as having it towed to be safe.
i wish i could be of more help but i really don't know.
good luck.
jd1200 Jul 9, 2009 08:21 AM
Thanks Brad
