Ford General Tech Ford tech talk within.
1987 bronco 2
Old 08-16-2004, 11:25 PM
bluecam's Avatar
Default 1987 bronco 2
a friend of mine has rebuilt his 2.9 liter V6. now it won't start and i have been asked to help him. I have tried anything I can think of to get it to start but have had no success.<IMG src=smileys/smiley11.gif border="0">it has 40 lbs of fuel pressure and tries to start but just can't get going.timing chain is correct-firing order is correct- fuel pressure is correct- but it only stumbles when you try to start it. anyone have any ideas?
Old 03-25-2005, 10:49 AM
Default RE: 1987 bronco 2
I know you said timing is correct but re-check to make sure TDC exc..., also at your own risk try starting fluid or carb clean straight to intake to eliminate fuel problems, is compression ok, how about coil etc.. it is usually something stupid you have already checked but not thorougly.
Divergent
Street/Strip
11
04-09-2007 05:06 AM
Divergent
10-10-2004 05:11 PM
blackbetty
04-22-2004 02:10 PM
84DustemDlux
04-22-2004 02:32 AM
Quick Reply: 1987 bronco 2
