-   Ford General Tech (https://www.truckforums.com/forum/ford-general-tech-39/)
-   -   1992 aod E-250 van tranny question (https://www.truckforums.com/forum/ford-general-tech-39/1992-aod-e-250-van-tranny-question-12714/)
cmangle 02-01-2010 10:53 AM
I know this isn't a truck question but maybe the same tranny question/situation is applicable to F-250 trucks.
1992 Ford E-250 trans replacement Throttle Valve cable
I am replacing the AOD tranny in my 1992 Ford E-250 conv. van.
I am hearing horror stories about making sure the throttle valve cable is adjusted correctly or I could burn up the replaced tranny.
Is this something I can do, I work as a mechanic in general and have broad mechanic skills wit the exception of tear down/rebuild tranny experience.
"IS THERE" a major problem with this "throttle Valve" cable that I should be aware of and can I re-install my used trans without the assistance of a tranny shop/technician?
