1997 F150 has a slight miss
My 1997 F150 has a slight miss under load at intermittent times betweet 2000 and 3500 RPM.
I have replaced everything that OBD suggested and there are no new codes, but it still hass the "flutter". Could it be the EGR tube is clogged? I'm stumped. Thanks |
what were the codes that you were shown??
Ford has had notorious problems with the egr. I've seen alot of misfires and busting up on the f 150's due to a bad coil pack. You might want to look into those. Usually the first one to need replacing is on the passenger side.
