Ford General Tech Ford tech talk within.
Code P0430
Old Mar 22, 2005 | 11:18 PM
goalee29's Avatar
Default Code P0430
Pulled a P0430 off the OBD port which is a "catalyst Efficiency below threshold (bank 2)". Does this mean that my cat is shot? That's my guess. Help!
Bill
Old Mar 23, 2005 | 02:35 PM
Patrick's Avatar
Default RE: Code P0430
it would be a cat or O2 sensor issue...
Old Mar 25, 2005 | 10:40 AM
DWhiteDevil's Avatar
sounds like o2, have you done any work to the truck recently, and after you clear the code does drivability change?
Old Jun 7, 2009 | 02:15 AM
AeSix's Avatar
could be a hole in the exhaust too.
If your gas has changed formulas drastically recently, detach the battery and let the system drain of power for a good half hour or longer. It'll reset your computer and sensors.
I had to do that with my truck when I came back to florida from Nebraska. I was getting crappy gas milage until I did. Now I'm back to normal. For me it was going from 15+% ethenol and high altitude to e10- and low altitude. still a simple thing to try before spending money.
jdoldno
Oct 7, 2007 10:15 AM
iascum
Jul 26, 2006 12:05 AM
iascum
Apr 20, 2006 02:03 AM
klrjoe
Dec 7, 2005 05:32 PM
montero91
Dec 7, 2005 01:31 PM
