-   Ford General Tech (https://www.truckforums.com/forum/ford-general-tech-39/)
-   -   Code P0430 (https://www.truckforums.com/forum/ford-general-tech-39/code-p0430-206/)
goalee29 Mar 22, 2005 11:18 PM
Code P0430
Pulled a P0430 off the OBD port which is a "catalyst Efficiency below threshold (bank 2)". Does this mean that my cat is shot? That's my guess. Help!
Bill
Patrick Mar 23, 2005 02:35 PM
RE: Code P0430
it would be a cat or O2 sensor issue...
DWhiteDevil Mar 25, 2005 10:40 AM
RE: Code P0430
sounds like o2, have you done any work to the truck recently, and after you clear the code does drivability change?
AeSix Jun 7, 2009 02:15 AM
could be a hole in the exhaust too.
If your gas has changed formulas drastically recently, detach the battery and let the system drain of power for a good half hour or longer. It'll reset your computer and sensors.
I had to do that with my truck when I came back to florida from Nebraska. I was getting crappy gas milage until I did. Now I'm back to normal. For me it was going from 15+% ethenol and high altitude to e10- and low altitude. still a simple thing to try before spending money.
