how to install a cobra cb into a 1988 ford bronco
I bought a cobra cb and want to install it on my bronco i have 2 red wires one says fuse 1A the other says fuse 2A I also have a black wire that i am guesing is the ground wire how should i hook this up? any help is very appriciated
RE: how to install a cobra cb into a 1988 ford bronco
Which model is it? I had a cobra CB in my jeep and it only had 2 wires, one hot, one ground. I ran an inline fuse from the hot to the fuse block and grounded it via the bolt that holds the driver side sun visor up.
May be I can be some help if you can give me your model no. Its really difficult to suggest solution without complete info...
