straight pipes effect gas mileage?
I think not. Straight pipe will not lower your gas mileage but will maintain it and just give your car better performance.
____________________
how to save gas
how to save gas
No effect,
No power difference,
No damage.______________________________________…
The only thing you would change is the sound.
In theory it would run lean on fuel, but it won't in the real world because assuming your O-2 sensors are working they will compensate.
I straight piped my truck completly granted there is and arguement that if theres no back pressure the engine will loose some power in the low and mid range. Thats a theroy and in no way true, if your really worried about it like i was at the time throw in a TBI or Carb spacer i noticed a big improvement on the butt dynoo
Straight pipe has no effect on engine performance and it's not going to lower the fuel efficiency. The only worse thing about it is its noise; yes it has a very loud and annoying sound.
at first your milage will be amazing because your afraid to sick your foot in it because of tickets however youll eventually build some confidence and develope a lead foot to hear the pipes flowin'. you will see a drop in low end proformace but that powers not lost its just put in the high RPM range so youll have to mod your engine to compensate if it drives you crazy like me. but dont run true duals use your exhisting header Y pipe and then use a second Y pipe to split into duals that should prevent crackling if you use the right size pipe and keep enought back pressure to insure you exhaust valves dont cool to quickly.
I plan on getting a Y pipe for my 2000 Chevy Silverado 5.3 because my cats went out but i was wondering since I have the flow master super 44 installed right now that it would limit the noise?
wrong about the damage it will burn your valves if you dont have any back pressure and if its before 1975 or 85 i cant remember off the top of my head but you can run open headers with baffles to make a little bit of back pressure and get away with it
