What transfer case models has Ford used?
What transfer case models has Ford used? Were any of them factory equipped with a slip yolk eliminator? Thanks everyone! Wm |
RE: What transfer case models has Ford used?
two that I know of early models72 to 78 NP205 t-case all gear driven came divorced in f250. super strong case. fix spicer yokes. 80 to 95 broncos & f150 used borg warner 1350 t-case fix flat 4 bolt flanges. 5.8L engines only. 5.0 used 207 slip yoke. the 1350cse comes ether manual shift or electic motor shift? if your in california call anahiem gear in city ofAnahiem they have what you need. if you speak to patt tell him alex from 4WP told you to call..hope this help you..
Excellent info man, thanks a bunch....that beats the hell out of crawling around in a junkyard all day of which I'd probably still not found the answer to my question! I've been looking for common boneyard parts that can be used to build slip yolk eliminators or vehicles that came with them stock that can be used on the NP231 and NP242 transfer cases. I'd also like to find a beefier boneyard upgrade to the NP231 and NP242 TCs....anyone have suggestions?
Wm |
