1991 F250 7.5l EFI loss of power under demand
Old Nov 4, 2009 | 05:33 PM
Luggingalong's Avatar
Default 1991 F250 7.5l EFI loss of power under demand
Pulling a grade yesterday and lost power big time , nothing over 2500 RPM .
Even when I limped too the top of the grade onto level ground .
Only after I babied it home cooled it with water over the radiator , turned it
off and let it set 10 minutes . Then fired it up and revved it a couple of times
did it finally kick up past 4K RPM . Question ; O2 , MAP sensors injectors
or fuel filter or pump ?. Where would you start to look for the problem ?.
Truck was warmer than normal when running
extremely dry air 7-9 % humidity but never got close to boiling over . it's
normal temp position is between cold and half , yesterday it was half way straight up .
Thanks Luggingalong
joshtowal
Feb 18, 2011 04:12 PM
Extacie
Jun 7, 2009 01:37 AM
DennisT
14
Mar 25, 2008 12:37 AM
Cvtsax
14
Feb 23, 2008 10:49 AM
mkfarren
Dec 12, 2007 06:53 PM
