1999 F 250 Misfire HELP!!!!!
I have recently bought a 1999 F 250 with a 5.4 and am having trouble with a misfire issue. I have passed emissions with no problems and have no current check engine light on. I ran the stored codes and found cylinder number five and six in the memory showing a misfire. After checking the plugs and boots I found the plugs in good shape and boots falling apart. I replaced the boots and had no results. All eight of the coil packs have been replace by the previous owner. What do I check now?????
A code P0305/P0306 may mean that one or more of the following has happened:
Faulty spark plug or wire Faulty coil (pack) Faulty oxygen sensor(s) Faulty fuel injector Burned exhaust valve Faulty catalytic converter(s) Poor compression Defective computer |
What brand coilpack is it?
| All times are GMT -5. The time now is 08:40 AM. |
