-   -   1999 F350 6.8L V10 No Code miss (https://www.truckforums.com/forum/ford-heavy-duty-101/1999-f350-6-8l-v10-no-code-miss-18670/)
99F350V10 Apr 23, 2012 06:04 PM
My 1999 F350 6.8L V10 has a slight (and what seems to be intermittant) miss. My code reader (Innova 3100) returns no errors, however. Any ideas on what I can test next? Here is what I've tried so far . . . .
(1) Installed new spark plugs.
  • Although the plugs that were removed were that old, I replaced all of the plugs with new ones after properly gapping each per Chilton's manual.
(2) Performed fuel pressure test.
  • Fuel pressure with key on and engine off equals 34 psi, which is within the recommended range specefied by Chilton's manual.
  • The leak-back <2 psi in 5 minutes (well within spec).
  • With engine running, fuel pressure dropped to 28 psi (normal).
  • Acquired resistance readings on fuel injectors (all within 11-18 ohm range as specified in Chilton's manual).
(4) With engine running @ ~1500rpm, coils packs unplugged one at a time.
  • Each time one of the coil packs was unplugged, there was a noticeable change in engine performance. This led me to conclude that each coil pack and plug was indeed working fine.
I did receive a comment from another shade tree mechanic about a a possible fault in the computer board. But I do not know how to test this, or even where it is located on the vehicle. Any advice here?
