2003 f350 5R110W TRANNY PROBLEM
Hello,
I have a 2003 F350 with 6.0 engine. Today, I noticed the tranny wasn't shifting into overdrive, the tranny temp guage was to the red and the tow/haul light was flashing on the end of the shift arm. I pushed the button and nothing happens. I checked the fluid and its right up where its supposed to be. This truck only has 25K on it. I checked underneath and everything looks good. Any Ideas out there as to what may be wrong. Thanks, Larry |
Check the VSS on top of the read diff.
Thanks. This problem has been diagnosed as a bad Transmission flued temperature sensor and replaced. Now works fine.
Thanks, Larry |
