2011 F350 4x4 Jerky Steering while in 4x4
Hey Gang,
When I select 4x4 in the cab, it engages just fine but whenever I need to make a turn while in 4x4 the truck jumps and lunges fwd. What causes this? Normal? It seems just fine while driving straight. Chris |
normal
Normal, within reason.......If you are cranking it hard, it is likely normal....if you are just slightly turning and it does it, your CV joints may be going. How bad is it?
