2012 250 Locking Differential
Old Dec 25, 2011 | 09:01 AM
PtownBubba's Avatar
Default 2012 250 Locking Differential
On the 2012 F-250 SD 4x4 with the 'electric locking' differential, sounds like a great idea. You hit a switch, and the rear end will lock,, putting full power to both rear wheels. Great, however lock means lock,,, it will operate like a solid axle, correct ? So turning on slippery or icy surfaces, would be a tricky move.
According to what I have read, when it is manually locked in, it will unlock at 20 MPH or so,, will it re-lock as you slow down for a turn or stop sign, or do you need to manually restore the locking mechanism after it clicks itself off ?
My concern is if this is still a good option for a truck for snowplowing, where your speeds are normally less than 20mph, locked in can you turn to miss a fire hydrant, or parked cars when plowing a snowy-icy-patches of dry areas- parking lot ?
So,,, is this a good thing or not,,,, many argue limited slip-posi traction is not that usefull as it tends to not really work that well, but it would be way more forgiving, and it does offer added traction,,,,,, but a true locked differential , be it a powerful addition, may put you into a storefront window. To say 'do not lock it in for simple plowing,' one's ego may not allow that, as soon as you feel a wheel spin, a guy may lock it in, more to show off,perhaps.
Austinite
Jan 12, 2013 04:33 PM
RaceSpeedworld
Jan 17, 2012 11:31 AM
OntheRoadAgain
17
Dec 12, 2011 11:49 AM
lwcrow
23
Dec 1, 2010 04:46 PM
Brutally_disgusting
Nov 29, 2010 03:06 PM
