6 Essential Service Truck Accessories To Consider
Some pointers to note when you are choosing accessories or designing your very own service truck:
Storage BoxesYou will find the need to organize your tools and equipment in your truck as no one likes a messy environment. Tools have to be placed in safe and secure storage boxes to prevent them from falling off during bumpy rides. These storage boxes can also be labeled to ensure that you can find your items faster and easily. This will definitely improve your work efficiency and keep your workplace hazard free. You will discover a whole wide range of tool storage boxes and do find out what kind of features are customizable to suit your company’s needs.Engine-Powered AccessoriesEngine-powered accessories in a truck can reduce the need to run its own engine. This can save your fuel and also save the environment by reducing emissions. You can either get auxiliary power units to store in your truck or get those special units with their own air compressors, generator, and hydraulics. They can hold a large amount of power supply and have built-in inverters. You will not expect any irregularity or jumps in your power supply due to its smooth generator.Lift GatesEvery service truck should have a liftgate. It is a metal platform to lift heavy equipment from the ground level all the way up to the height of your truck. It will appear as a fold-away metal platform attaching to the back of your truck. Additionally, if you require a dumping function, some lift gates do provide both a liftgate and a dump-through tailgate in a single piece of equipment.LED LightingYou will need good lighting for your trucks. LEDs are highly energy efficient with less amount of heat emitted and lower cost. You can utilize less electrical energy for the same light output, hence reducing your cost.Ladder RacksLadder racks can ensure safety while loading and unloading a ladder. You do not need to manually haul your ladder in and out the back of your truck as the ladder rack helps you do the work. Choose one that is automated, easy to use and also durable.Spare Tire RacksYou will need some spare tire racks to place your spares. This is usually placed on the outside of the truck hence saving space and providing greater accessibility.There are many other accessories such as the following.
