-   -   ac problems (https://www.truckforums.com/forum/ford-heavy-duty-101/ac-problems-14733/)
ricksharp63 Sep 24, 2010 07:55 PM
ac problems
ac is blowing hot air, I have checked the pressure and fuses. Could it be the compressor? how would you check it?
geomath Sep 25, 2010 05:39 PM
check the A/C clutch first
Does the A/C clutch engage when you turn the A/C on?
ricksharp63 Sep 26, 2010 05:16 AM
Unfortunately it does not, probably the compressor. Is there a way to check it?
geomath Sep 26, 2010 09:28 AM
Clutch
From my experience, if the clutch does not engage then the whole compressor gets replaced. There might be a way the replace just the clutch and then try it but that I do not know how to do. As for checking the compressor, you cant tell if the compressor is actually compressing if the clutch does not engage. :(
ricksharp63 Oct 2, 2010 04:16 AM
The ac clutch came apart so I have to replace the compressor and accumalator, dealer wants $1000 to do it, I will do it myself for less than half that.
geomath Oct 3, 2010 08:53 AM
wow
Seems like you could replace the whole thing for far less than that :eek:.
I think I might go out and buy some parts for my truck and store them till they are needed :cool:. It seems to me that parts and even affordable mechanics are getting harder to come by :mad:.
Hey, if you can, maybe take pictures of the process and post them. It would be interesting to see how it is done :D.
Good Luck!
ricksharp63 Oct 12, 2010 05:34 PM
I ended up taking to a local mechanic, he only charged me $600 for the whole thing.
ricksharp63 Oct 25, 2010 06:46 PM
Got rid of the piece of s*%^ and bought a GMC 2500HD 6.0 gas
