-   -   Brakes: hissing and lights (https://www.truckforums.com/forum/ford-heavy-duty-101/brakes-hissing-lights-13812/)
80skeys May 27, 2010 09:07 AM
1983 F250 with 351 and 3spd automatic.
1) When brakes are not pressed, there is a hissing sound coming from the engine compartment. Press the brakes and the hiss goes away.
2) Press the brakes and dash lights inside the cab come on. Un-press and they go off.
Thoughts?
80s
Crazy ACE May 28, 2010 06:31 AM
Hissing is air in the system or the fluid is old and broke down. I would chase wires to see if when you press the brake pedal you're not grounding on any wires.
Worf May 29, 2010 07:59 AM
i agree on both points above. If you mean the dome light comes on when you hit the brake then you have a short somewhere.
