could somone tell me what this looks like?
1 Attachment(s)
i drive a 1996 F250 V8 351 5.8L
and my suspension needs replaceing, but i havn't a clue what is in this photo, i think its a 2 in lift kit, but i'm not sure. i need some advice. *attached file related* |
if that is what needs replacing that is your leaf spring going across the screen. if you get on the ground and look behind the tire about 2 feet back under the bed of the truck that is what you will see. what else do you need.
I know The leaf Spring is in thsi photo, I probably Should have been a bit more specific, the point between the leaf spring and the axle itself, is what i'm interested in. I'm trying to figure out if that is just a stock lift set up, or is it a 2 inch lift kit, an old one at best.
Oh ok. In that case I do not have a clue, I have never but a lift on a truck and I have not seen that type of block on any stock suspension. Though it could just be the way the older ones were set up. Anyways sorry but I can not say for sure weather it is stock or not.
| All times are GMT -5. The time now is 04:08 AM. |
