-   -   Engine Conversion F350 4WD V10 Triton / 460 with carb. possible? (https://www.truckforums.com/forum/ford-heavy-duty-101/engine-conversion-f350-4wd-v10-triton-460-carb-possible-8333/)
Eastfrisian Nov 5, 2008 04:30 AM
Dear All!
My name is Ingo and Iam from Germany. I have a question regarding my F350 and Ineed your help.
I havea 2003 Ford F 350 Super Duty 4WD Dually with a V10 Triton gasoline engine and automatic transmission.
BecauseI am notsatisfied with this engine,I want to install a modified 460 engine with carburator. Iknow that this plan is very strange, but I want to realize this project. If there is a way to realize it,I will do it.
The biggest problem now is to clarify if the engine will suit in the car and what we have to do for mounting the engine and to connect the OEM transmission. Can we use the original mounting and will the transmission match to the 460 engine or have we to buy a suitable transmission or adapter?
Regarding the computer and exhaust we will not worry (at the moment). Do you know if the engine and the OEM transmisssion can ben connected?
I am looking forward to hearing from you and many thanks for your help in advance.
Best regards,
Ingo
