-   -   F-250 with problems (https://www.truckforums.com/forum/ford-heavy-duty-101/f-250-problems-17198/)
dnifong Aug 1, 2011 08:53 PM
F-250 with problems
greetings, I just bought a 2008 super duty with a 6.4 motor. 102k. mostly highway miles. Main problem is, it uses about 1/2 gallon on coolant on a tank of gas. Can not find a visable leak. does not smell while running. today, after asking 2 or 3 mech's i'm about to sell the truck. they stated that the cylinder sleevs are prone to fail on this motor.
1. is this true? If not, what is a common failure item of the cooling system.
2. seems like the starter is not disengaging quickly after the switch is out of start position.
Also, what can I expect from this beast as far a common failure. the thing will surely pull the crap outa my boat:)
thanks, dale
