F250 Transmission/shifter indicator
Old Sep 17, 2010 | 06:38 PM
PtownBubba's Avatar
Default F250 Transmission/shifter indicator
I have a 2002 F250 AT 4WD. It is acting a lil' funky with shift/gear indicator.
There seems to be a lot 'slop' with column shift lever. In D,,, the indicator is to the far right of the D,, you can free move it to the right side of N. Maybe not a big deal,, but at times it is hard to find drive and even reverse,, you have to rock the shifter back and forth to find sweet spot. I do plow some snow, not much but some,, so the shifter/linkage has more than the 69000 miles on it. So,,,, could it be sloppy linkage,,, there seems to a small lever or pivot at the bottom of steering column,,,, could that be worn ???? Maybe just order one of those,, can't hurt to replace it ???????
Once in gear [ r or d ] all seems fine,, no herky jerky,,, moans or groans,, or slow or sluggish shifting,,,,, r and d are just hard to dial in ,,,,,, Any ideas ???
cook134
Mar 22, 2014 11:59 PM
bradyjames
Jul 27, 2010 09:28 PM
JAGER94
Automotive Parts Wanted
Apr 19, 2009 03:50 PM
tailtap
Nov 2, 2008 10:06 AM
lowtoyz2
Apr 24, 2007 07:04 PM
