F350 6.0 problem with intrument panel
Today al my gauges stoped working along with climate controll, the nice beeping noise when you forget youre keys in ignition, windshield wipers and i cant locked my car with the remote button. Or the button on the door that lockes the car. Everything else workes fine. Need some serius help. I live in sweden so the support on the real american ford aint good. I hope to have some luck here.
I have checked al the fuses. Every one is okay
What year is your F350 6.0L ???
It is a 2006
Can this problem that i have. Have any realations with the key ignition lock?
That could very well be your problem. Your ignition switch (key) operates a cam that, when turned on will move forward to push the cam that then pushes a switch mounted on your steering column. This switch will turn on all your electronic devices.
Al of these problems have acured after my batteris went low on voltage. How can that be?
It could be that your truck needs to be reset - disconnect the battery for 10 minutes and let everything reset. Reconnect it and see if your problem is solved. You should also make sure you battery is fully charged before attempting repairs.
Is your check engine light on? Do you have access to a scantool to read DTC codes? |
I am recharging the batteris, and hopefully the will be fully recharged on tuesday.
I cant se any engeine light. When i turn the ignition to position 2. The only lights that works is the battery lamp and airbag. None of the other lights is on. I am going to try and se if can find a repair shop today that have a scan tool. The car starts but i runs in some kind of emergency program. It has no power and i dont think it will change gear when in Drive.. |
Well newly charged batteries dident do the job. I am leaving it to a workshop on friday he has a scantool from bosch. Dont know if it will work.
well we all know what happend the last time when germany and the us came in conflict. :) Hopefulle this time they will get along better. |
