F350 Brake Rotor Removal
Old Sep 20, 2006 | 01:26 PM
daggettdaddy's Avatar
Default F350 Brake Rotor Removal
I picked up a 2002 f350 3 weeks ago. the front brakes were shot. The caliper on the driver's side front needs replaced as well as the rotor. The caliper is no problem. But I've never pulled a rotor before. Does anyone have any advice?
Old Sep 20, 2006 | 08:32 PM
xtreemnoise's Avatar
Default RE: F350 Brake Rotor Removal
Is your truck a 4x4? normally rotors are slid over the hub & may be retained by a couple bolts. Removal after it's been on the road for awhile can require some persuasion with a dead blow hammer. As always thou having a manual handy can answer most questions
Old Sep 24, 2006 | 01:13 PM
Yes it is a 4X4. I received some advice from a friend. He is a MOOG mechanic and has delt w/sticky rotors before. It took about 5 minutes with a propane torch to warm the rotor up enough that it pulled easily off the hub assembly. (Be very careful not to torch the plastic parts of the hub.)
greentruckford
Apr 10, 2010 03:33 PM
bpa1216
Mar 21, 2010 05:40 PM
Clubmike2910
Feb 28, 2010 06:35 PM
bfg112
Jul 8, 2009 07:05 PM
lossinthought
Sep 24, 2006 06:18 PM
